Exhaust Manifold Flange Gasket
Mystique
California
Does anyone know the difference between these two gaskets? Based on the description both gaskets would fit my 97 GTS. I ordered the copper one but the ticking noise from the exhaust flange is still there. The other one looks thicker and might create a better seal. Anyone have the correct part number? Appreicate any insight, thanks much.
Mystique
Mystique
California
I got you my dude. Depends on your stock exhaust manifold outlets. What Gen/year do you have?
Mystique
Mystique
California
I thought Gen 1 was 92-95 with Gen 2 starting in 96. Either way need to look at the outlet of your stock exhaust manifolds. The correct gasket is dependent on the design of the outlet. This an easy install provided you have the right gasket. Take a look at the picture of the Viper manifolds and notice the exit designs are different. Which one do you have?
davidbr
Germany
If the donut style gasket is the same as in the Gen 1 the part number should be 4763481.
Can you tell me how thick the flat copper gasket is? About 0.1"?
