Sonny 00 GTS ACR
Examining my 2000 GTS ACR I noticed something strange. The right rear shock assembly appears to have come from the factory mounted backwards as the adjustment window in the top eye is pointing towards the differential instead of the wheel assembly. My question is if I disconnect the top eye by removing the bolt attaching it to the frame, can I leave the clevis bracket attached and spin the top eye 180 degrees without changing the setup? I'm assuming that the shock absorber shaft would allow for that movement, but I'm hoping that some of you would confirm that for me.
Thanks!
Thanks!
