steel snake
The owners manual is not much help for adding coolant to a low tank. There's got to be a better way. The overflow is almost empty. Can fluid be added to the pressure tank when cold. Is there a set fill level in the press tank when cold? Also how far do you go to pamper your Snake. I use a clear vinyl plastic sheet (before the cover) that copletely covers the cockpit to keep the "new" smell in my RT10 and keep dust out. It's like heavy duty Seran wrap and clings to the glass and paint (no it doesn't hurt the paint). Thanks in advance if you respond.
