Door sags just a touch and does not line up with rear quarter. Bottom needs to come up. Do I remove the panel nextto the door to to the hinge bolts
I would have guessed this was the easiest way as well, as I have noticed my door is a little low at the quarter till it hits the striker. At which point it lines up perfectly.it will move up, down, in and out- loosen the hex bolts enough to make it a little hard to move, keep tweaking till you get it perfect- this is all you need to do.
