Any words of wisdom for driving in the rain.... other than "DON'T "
Gottaviper
Boston Ma.
Any words of wisdom for driving in the rain.... other than \"DON\'T \"
I may get caught in a bit of rain driving home from IL. tomorrow. TIA
Jim Hodel
Portland Or
Re: Any words of wisdom for driving in the rain.... other than \"DON\'T \"
The only thing I can think of is wash it when you get home. Seriously, I drive my 99 GTS rain or shine and the only 'problem' I've observed is that it get's dirty. I know the Viper has a reputation for not handling well in the rain, but I honestly don't know where people get that idea. The Pilot Sports have plenty of grip and the car is nice and predictable - so no problem.
Jim
Cape Coral, FL
just dont go exceedingly fast, and watch out for collecting water. DO NOT accellerate fast from a stop or while making a turn. other than that, it isnt really a big deal. I have done about 1000 rain miles, no problems if you are careful.
Bad_Byte
Corpus Christi Tx
One word >>>>>>> TOWELS
Take a few with you.
Driving in the rain isn't bad. Remember, EASY on the throttle. Some of the most fun track times are on rainy days.
V10 MOJO
Youngstown, Ohio
viper drives just fine in rain, no worries, have fun
utahviper
Utah
THe only problem I have seen with the viper is that once it starts to go sideways in the rain it has a tendency to go all the way around. Easy on the throttle in turns.
Mike_W
My Viper does not feel good in the rain.
I also have a Lexus lowered on some type of coils or struts or whatever they are called. Anyway, I paid only $1K for them, and $200 to have them installed. My Lexus feels about 3.476 times safer driving around corners, and about 5.72 times safer in the rain than the Viper. The Viper just does not feel safe.
Mike_W
Oops, sorry. I did the numbers wrong. The Lexus feels 5.73 times safer. I forgot to round up, and I don't want to mislead anyone.
Mike
GTS Bruce
Orchard Park,NY,USA
Make sure you use some rain-x or equivalent.Bad visibility down there in all the rain,spray mist and slop. Bruce
jcaspar1
Sacramento, CA
I have driven my GTS in the rain many times. It is actually a pretty good car for winter (snow free) driving. The windshield is a steep rake that the water usually just sheds off it at speed. The wipers are the coolest on any vehicle I have ever seen. And I rarely need to use the heater as the car is always hot. If you have your original tires I would not consider driving in the rain!!
Moundir
Ny
Are you guys kidding me, I did 140mph in the rain going wot in 4th :p You guys underestimate the handling of the snake :headbang:
Mike_W
You're NUTZ.
Mike
viper spray
Austin, Texas , USA
Stay on the gas and brakes HARD , to get the feel of real traction . Push it untill it slides!!!!!!!(both ends)
Dimitrios
Queens, New York
just drive it..when coming upto sharp turns lay off the gas and let it ride in gear. car pretty much sticks to the ground especially with the pilot sports. avoid puddles. take care
Saratoga,CA
Simple Physics - think about trying to turn a flat bottom boat vs a deep V. Wide tires = a flat bottom boat. The Pilots are good compared to other tires of the same size but hit standing water going fast will be a big problem! If it rains hard slow down or stop for a rest. Hope you have a safe trip.
G
Gottaviper
Boston Ma.
Thanks guys. Off I go to the flat lands of IL.
Chuck 98 RT/10
tampa, fl USA
94 RT? I hope you don't have the original tires. The new Pilots do well in the rain.
HOGGG
Omaha, NE
I took delivery on my RT in ILL at Roanoke and drove to Omaha in the hard rain. First time driving the Viper and had no problems. Have fun.
:usa: :headbang:
95Viper
Phoenix
Get the inside of those sills dry afterwards! Water trapped and sandwiched against the sill by the insulation and heat shield barrier breeds the aluminum corrosion many have seen. Sometimes people park their Viper after driving in the rain and it might take two weeks for that area to dry out considering the lack of air getting into the area.
JGarrett
Austin, TX
You can go just as fast in the wet as in the dry....you just can't turn or stop as well. Seriously, get braking done early in a straight line and be judicious with the throttle. With good tires hydroplaning starts at about 9 times the square root of the air pressure. At 36 psi about 54 mph. Of course the you must also look at adhesion the tire is capable of on a slick surface. Figure cornering capability between 33-36% of normal.
Cheers,
Jim
This should stir the ***.....
GTSTF
Glenview, Il. USA
i drove down to VOI7 in Nashville in the pouring rain. didn't even realize i was going 85-90 m.p.h. until i looked down at the speedo. no problems at all driving in the rain - though i haven't done it since. don't want to make a habit of it.
Bonkers
DelaWhere? USA
On fairly new pilots I ran autoX at the NE Rendezvous in good dry weather to utter downpour and I didn't notice any traction difference.
The only thing I would look for are the obvious slick spots (where the asphalt/concrete has been polished by too much traffic) and off-camber corners (like off ramps) where the weight off the car goes to one side without compressing the shocks.
