Anyone ever go up against this car? If so what was the outcome?
JENJGTS97
South Carolina
Anyone ever go up against a 2011 Mercedes Benz SL65 AMG? If so what was the outcome? Interested to know because I had the opportunity to do so this past weekend and I was amazed how well my stock (except exhaust, K&N's, and smooth tubes) 1997 Viper B/W GTS did against it in 2, second gear rolls all the way well into 4th gear. Pulled the Benz by about a nose at top of 3rd gear and same in 4th until we had to let up. Very evenly matched. Very safe surroundings on old air strip. Just ran out of room to keep going. Two beautiful cars letting it all hang out with pretty much an even outcome at the end.
bluesrt
that was me, i was just goin easy on you, i was only at half throttle
twinvipers1
Had to be an 09. Only year they made the new body style. I own one. Car runs 11.0 with just a tune and a tire:)
Timnineside
West Michigan
Where is this Air-strip you speak of? Been looking for one to privately rent in the Michigan/Ohio/Indiana/Illinois area.
plumcrazy
ALL OVER
ran one back when i was stock plus nitrous. he had exhaust tune and something else, i beat him pretty easily. then ran one of the new weird looking body style ones with the huge fender flares in the spring and killed it...
99 R/T 10
Enterprise, AL USA
Yeah, but that wasn't a fair race. You added the Vipair and gained 50 RWHP.......................................
martyb
IL
I have seen the SL65 run 125-128mph trap speeds with just a tune, hard to believe an almost stock GTS will run with one. I'm with Phil.
AAKVIPER
Princeton area ..Central NJ
Boys check the data..The Viper has faster MPH..and with the right hook up on tires..
The Viper can shave a couple tenths off. The Merc with more 61 HP can not overcome the weight difference of the Viper.
Compare the Merc and Viper from 0-140..The Snake comes alive even more..
Arthur
http://www.carforums.net/showthread...-Black-Series-Murci%E9lago-LP640-Viper-SRT-10
SL65 BS
$304,350
4220 lbs52/48 Weight Distribution
twin-turbocharged SOHC
36-valve V-12 365 cu in (5980cc)
Front Engine-Rear Drive
661 bhp @ 5400 rpm738 lb-ft @ 2200 rpm
Redline: 6200 rpm
Lb/bhp: 6.4
5 Speed Automatic
0-30 mph: 1.6 sec
0-60 mph: 3.6 sec
0-100 mph: 7.6 sec
0-120 mph: 10.5 sec
0-140 mph: 15.0 sec1320 ft, 11.7 sec @ 126 mphStreet Start, 5-60 mph, 4.0 sec
Top Gear
30-50 mph, 2.0 sec
50-70 mph, 1.9 sec
70mph-0: 152 feet
0.93 g
Top Speed: 199 mph (governor limited)
SRT-10
$98,060
3420 lbs50/50 Weight Distribution
pushrod 20-valve
V-10 512 cu in (8382cc)
600 bhp @ 6100 rpm560 lb-ft @ 5000 rpm
Redline: 6250 rpm
Lb/bhp: 5.7
6 Speed Manual
0-30 mph: 1.8 sec
0-60 mph: 3.6 sec
0-100 mph: 7.8 sec
0-120 mph: 10.4 sec
0-140 mph: 14.2 sec1320 ft, 11.8 sec @ 128 mphStreet Start, 5-60 mph, 3.7 sec
Top Gear
30-50 mph, 10.5 sec
50-70 mph, 9.8 sec
70mph-0: 162 feet
1.02 g
Top Speed: 202 mph (drag limited)
SoCal Rebell
Mission Hills, Ca USA
Re: Boys check the data..The Viper has faster MPH..and with the right hook up on tire
Watch out for the Brabus, Renntech and new MBK 1,000 mods, they put down between 800-1,000 hp.
plumcrazy
ALL OVER
AAKviper, OP has a gen2 not 3. and i dont believe a gen3 would beat it either personally
terminator02
Detroit Michigan
Isn't the general rule a 1/10 off the 1/2 for every 100lbs? The 600hp viper has an 800 lb advantage over a 68hp loss. I would say it's a drivers race any day. Obviously aerodynamics would factor into the "general rule." But ya, a gen2..no way. However it wouldn't be a complete blowout. A decent driver should be pulling 12.00 on that gen 2 the OP has.
AAKVIPER
Ok the Gen 2 was in question..I misread the post ..my bad..:)
but the from other tests I read the SRT-10 is faster in a straight line...and on a race course the Viper embarrassed the Merc.
Not sure why it is hard to believe that the Viper is faster then the Merc. I would expect the Viper to be by, logic.
Power to weight ratios Merc is at 6.38
SRT-10 is at 5.70
rthorley
wait they OP stated an SL 65 AMG not an SL 65 AMG black series the black series is a completely different car
notsoslow
