anyone hook up fogs on their acr?
2kgtsacr
Central PA
Has anyone tried? Is it possible? I know its one of the signs to tell if its an acr but I think it just looks weird without them.
redtanrt10
Dana Point CA
On the Gen II ACR's the plugs and the light switch are there. (Lot's of folks like me installed the factory fog lights). I'd bet they are also there on Gen IV's. If you do install don't loose the black cover plugs, they're hard to find.
2kgtsacr
Central PA
awesome thanks, I guess I'll have to give jonb a call for the covers for the fogs or do you not or did not use the covers?
AZTVR
Chandler AZ
If you do install don't loose the black cover plugs, there hard to find.
Previous owner did mine, and I like the look better, also. I don't have the blanking plates, so, if you don't want to keep track of them, please send them to me. I would like to pass along the OEM stuff to the next owner someday. (But, I don't care enough about it to buy them.)
I would like to see a picture of the removed blanking plate just for the record, in case I or someone wanted to make one. Is it metal or plastic ?
redtanrt10
Dana Point CA
I would like to see a picture of the removed blanking plate just for the record, in case I or someone wanted to make one. Is it metal or plastic ?[/quote]
AZ, plastic, fairly thin, buried somewhere in my garage, if I get a chance today I'll send you a picture.
awesome thanks, I guess I'll have to give jonb a call for the covers for the fogs or do you not or did not use the covers?[/quote]
2k, you remove the black covers and use stock fog lights. The plug for the lights is already on your car. Don't toss the cover plates, just like the ACR smooth tubes, expensive from Dodge and hard to find.
redtanrt10
Dana Point CA
AZTVR, Here's a couple of pictures. The covers have a texture on the outside and smooth on the backside. No part numbers are on them so a good copy would look OEM. I measured them and their slightly thicker that 1/8" Mike
AZTVR
Chandler AZ
Thanks !! :2tu:
