B
Bob Weidenfeller
Guest
Trying to install an Autoform hardtop on a 98 RT and having a little bit of a problem. The top itself fits and looks great, but the bracket in front that hold it down doesn't seem to fit. Right under the wheel on the bracket where the attaching wire rides, there is an inward bend of the metal bracket as if it is supposed to slip under something. On my car, and I assume on all '98s, is a plastic body piece attached under the window, behind the door. This does not allow the bracket to mount flush.
While it seems straight forward to straighten or remove this bend in the bracket, I thought I'd check if anyone else had this issue?
I'll call Autoform in the morning, but was hoping to put this thing on tonight and test tomorrow.
Bob
Bob
