BATTERY DASH LIGHT ON/NO ELEC FAN/ NO A/C! HELP!
onebadviper
Jackson, Mississippi USA
I have a 1994 RT/10. Today while crusing I noticed the battery light on my dash came on. At the same time the A/C quit cooling and the engine started to heat up. I stopped, checked under the hood and the electric fan had quit running. What has happened? I check all the fuses under the dash and all are good. I also checked the two fuses that are by the main electric box where the battery cable hooks up, and they are good too. I don't know what to check next. Please help.
Thanks,
Warren
(onebadviper)
Vip-RT10
Clearwater,FL.USA
How old is the battery? That may be a problem or maybe your alt quit? See if your fan relay is fried. It is on the passanger side, below the heater airbox, close to the fire wall. There will be 4 relays there, you need to see the group of relays closer to you. The first is the A/C compressor relay and the second is the fan relay. Hope this helps you.
