best location to place jack?
Leslie
Indiana
decided to change out my battery to a yellow top optima-any suggestions on where the best place is to lift the viper in the back?
also-anyone else have an optima battery in their viper?
thanks :headbang:
Randy
Earth?
Best location to place the jack is at the jacking points :cool: - the loop of 3/8" diameter rod that is welded to the frame just in front of the rear tires and just behind the front tires - its there to lock the stock scissors jack in place. Of course, if you've got a low enough floor jack, you can also use the underside of the suspension attachments to the axle - then you don't have to jack up quite as high, as the suspension will remain loaded.
L
Leslie
Indiana
awsome thanks Randy! have never lifted my viper (obviously) haha
Vic
I keep mine in the trunk.
Oh, you didn't mean that? I see.....
In that case, what Randy said. :)
ViperJohn
Maryland
Leslie, you want to put a red top, not a yellow top in the car. I will see if I can find the part number.
twinturbo3150
I believe yellow top doesnt have as many cold cranking amps, but are awesome for stereo due to there fast dishcharge and recharge rate. I would go with the redtop
GTSnake
Motor City
Just remember some Vipers have clearance problems with the Optima posts. You might want to check your clearance before you buy the battery. And of course don't cut down the post to make it fit.
GR8_ASP
Wow, no smart assed comments. I woulld have guessed some Jack Daniels related comments (like in my stomach via a small drinking glass). Course, since Leslie started the thread it could have some other connotations.
Too serious here.
L
Leslie
Indiana
makes sense, thanks
ok so I recruited a guy to come over and change the battery for me, took the day off of work, supposed to be 55 degrees out and sunny, and me in my Viper that's been sleeping since Nov
what could be better :headbang:
L
Leslie
Indiana
Optima 75/35 is the battery others have successfully fitted.
yehp, just figured that out! haha ran back to autozone, returned the yellow top, tried to fit the red top in and it wouldn't go
thanks to the threads here, saw somebody else got the 75/35 to fit:) ran back again to autozone and got the 7535
fit like a champ
viper is up and running again!!!!! can't wait for Saturday-supposed to be sunny and 70 degrees!!!!!
thanks guys:)
