Black Top Injector Flow???
ViperRichRT10
Suwanee, GA
Can anyone tell me the flow rate on the black top injectors? Are they any good?
Thanks...I have no idea what they are rated.
Thanks! :confused:
ViperRichRT10
Suwanee, GA
I have a Roe SC and Sean included them with my kit to replace my stock Gen II injectors. They must be better than my stock ones??? They replaced my red tops so I would think they would be better than Gen I's?
1TONY1
Dalton Ga. (Chatt. Tn.)
52 or 53 lb/hr ????
Do you have the extra black box that works the (low impedence) injectors ? R U sure they are black or .... are they navy ?
It's still not enough, keep trying ;) :D
NOT THIS :rolleyes:
:cool:
KenH
Portland, OR, USA
They are 53lb which is about 550cc. As Tony mentioned, they are low impedance (1.2 ohms) injectors so you need a 10 ohm load box from Roe to drive them with the high impedance VEC2 if you are currently running his earlier injectors (or factory type).
Joseph Dell
Atlanta, GA 30338
You sure those are low impedence? I don't see a low impedence driver box on Rich's car but I did see the black injectors. Any chance they are something else?
JD
Simms
Pittsburgh, PA
My black tops are low impedence. However, I believe the older ones Roe used to use were not. Of coarse they may not have been black tops either, my mind is slowly going these days.
1TONY1
JD
Have those injectors been changed since the s/c install ?
ViperRichRT10
Suwanee, GA
Well, they are the black with low impedence. They have the box, and guess who installed it? ;)
I know blue looks like black in the country Tony, but they are black!
Thanks for your help guys!
Shelby3
liu;g
The black are 53 lb/hr and the green are 50 lb/hr. Both are low impedance. Sean made the switch from green to black as a matter of availability.
Missjazzyfitness
