Brake bleeding/fluid change
Saratoga,CA
If you drive on the street only and the pedal is firm no reason to touch the fluid. Vipers at Track events with drivers that brake hard can boil the stock fluid. Going to Motoul 600 and adding deflectors solve that problem for most. When going to the high temp fluids a new variable is introduced. The high temp fluids absorb moisture which will reduce the boiling point and corrode the brake components. Solution flush (replace) the Motoul frequently (3-6 months and before each track event).
