PhoenixGTS
I have stock pads about 5k-6k miles old with all street driving. Inspection with a flashlight shows LOTS of pad material remaining but rotors are pretty hammered with a ridge outside the friction area. They have always been a squealing noisy pad at low pressure applications (like when you roll to a stop at a light and everyone thinks you are a loser who cannot afford a brake job on your Viper), but gradually over the last few weeks the brakes are now making a new strange kind of squeal noise that is almost like a synthesized electronic sound effect at zero and very low pressure applications. The noise is worst when you first back out of the garage in the morning, and abates when the brakes heat up. Could it be that once you wear the pads down far enough they lose their chamferring as directed by the service manual? And that those under-chamferred edges make this odd noise at low pressure applications? Biggest thing I am worried about is that the noise is wheel bearing related as it seems to specifically coming from the passenger front. Any ideas?
