??Broken water pump????
syclone1157
Rockwall TX
So I'm pulling into my house from a 2 mile run to get some gas when I smell radiator fluid. The car was a little warm but nothing crazy. I left the car running and popped the hood. The reservoir was empty. I turned off the car and took the top off of the reservoir, no steam. I filled the tank and started the car. It must have taken about 1 gallon to finally fill the tank. I then noticed a very thin stream of water shooting out of the side of the water pump. It looks like the gasket failed.
So my question is:
Was is it just the gasket or is this a consequence of a failed water pump?
Do I change the gasket only or go ahead and change the pump out as well?
How much should I expect to pay?
Thanks,
Martin
BDZ1984
Frisco, Texas
sounds like a timing chain cover gasket.... Had this fail on my car and sounds like the same thing that just happened to you.... Keith Laxson helped me out when mine failed....
GTSPOWERED
Ohio
When my gasket went it dumped all the coolant into the crank case. I had the dealer pull the pan and inspect all the bearings (no damage) flush out the motor 3 times after replacing the gasket.
Viper Wizard
South Salem, NY USA
Hey Martin,
It may be the timing chain cover gasket?
Timing chain cover gasket #4763745AB MSRP $22.85
Water pump gasket #4763790AB MSRP $13.25
Water pump #4763776AB MSRP $432.00
It should only take 2-3 hours to change all of the above.
I have everything in stock if you need it [less 20% VCA]. :cool:
