Buying a used GTS
SoCal Craig
Mission Viejo
I may be buying a used GTS next week and wanted to know what to look for to determine if the car is in good shape. Are there any recommended Viper service specialists you can recommend? The car is located in the San Diego area. I live in Orange County.
TIA
Craig
SteveBCloud9
Roselle IL. usa
Do a search on the subject. There have been several posts about it. Keep doing your homework. Carfax, vehicle history, accidents, re-painted, salvage, etc. The best thing to do is take one of our local members to buy the car. They can tell you a lot about the car and if it has/had problems. Good luck.
Venom Lover
Santa Barbara, CA USA
Have a Viper Tech in the San Diego area check it out. I don't have any references down there.
What you should check out are general indications of wear, including the condition of the upholstery, the paint (especially under the chin), the wheels, etc. You can pretty much tell if the car has been thrashed.
Good luck with your purchase!
dtittle
Austin, TX 78732
Hi Guys,
Here's how I look at a used Viper:
1) Using a flashlight look into the front wheel well in front of the tire. You'll be looking for the angled bracket that connects the facia to the rest of the car. It has four bolts. If they're not in their original position (ie washer marks), beware the facia has been adjusted implying a wreck in the front.
2) Lay down on the ground and look at the connecting hardware for the side sills. If they're not in their original position, beware as they imply a wreck from the side.
3) Look closely at the rivets that connect the rear fenders to both the wheel well and the inner door sill. If they're painted or anything other than black with the rivet shaft showing throught the middle, beware as the rear of the car has been hit or worked.
Obviously, you need to be able to detect things like orange peel or paint overspray. However, a Viper is typically painted by a shop that is meticulous enough to cover the tracks. The usual give-away for damage is washer marks where bolts where moved. That's why I tell you to look at the six critical areas mentioned above.
I also look at all suspension adjustment points since you can usually tell if things have been moved for alignment or racing adjustment.
Other than that, the general condition of the car is the story. Look between the seat and the transmission **** or the outer sill for debris or dust. If it's there, consider the mileage and wonder why those things are there.
The car is so beautiful that it's easy to miss the forest for the trees.
If the trees are damaged; I say "Run Forest, Run"!
Good Luck,
luc
Paso Robles CA
David,
I will have to disagree with the # 1.
I have a 2000 GTS that I bought brand new and the 2 bolts on each side,that connect the brackets to the inner fenderwell,are now toward the end of the slot on the brackets,but indentations on the brackets show that at 1 time those bolts were at the beginning af the slot.
Why? I have no idea but must have been done at the factory.
Luc.
Motor City Mad Man
Las Vegas, NV
If the white Viper lettering on the front brake caliper covers has turned brown then it has been driven ******* the track. Look for that.
Qualitywires.com
Louisville, KY
also look at the calipers where the Viper logo is and make sure it white and not yellow....could have been tracked hard.
