Can someone give an Update on Kumho's & Rocks
MR VENOM
Newbury Park, CA, USA
Can someone give an Update on Kumho\'s & Rocks
Have the OEM tires, only 7K miles, but the "rears" are so hard that the car gets "sideways" on a power shift into second. I know they should be changed (I think I will leave fronts original). Read some older and newer "threads" about the Kumhos throwing rocks. Since they have been out there awhile, what is your latest opinion. The Car is street use only and I want to keep it looking reasonably nice. Socal car, rain not an issue; not a daily "driver".
GONABITE
Albany NY
Re: Can someone give an Update on Kumho\'s & Rocks
the Kumhos will throw sand and stones on your car but they are definetely worth it hte traction is awesome with 610 RWHP and and 3:45 gears I can roll on the car full throttle in first gear and power shift into second with minimal tire spin.
1TONY1
Dalton Ga. (Chatt. Tn.)
With the rears the black inner wheelwell and the painted lip get some sandblast damage but nothing outside of that. Fronts are a different story, side sills get alot. I have about 4000 miles and the rears are wearing good, fronts are in need of replacement.
joe117
Maryland, USA
I have the Kumho exta700s. They do pick up sand and small stones, this makes noise. I haven't noticed any sandblasting of the paint. Very good traction, no warranty, not for use in rain. They don't cost very much.
varanus
pleasanton,ca 94566
I must be the unlucky one. My rear inner fender lips are virtually white from all the paint being blasted off. I will get them repainted and have 3m put on. Once who experince the traction, stock tires just won't cut it anymore.
99 R/T 10
Enterprise, AL USA
On the way up to the track, mt friend had to drop back about an 1/8th of a mile because he was getting pelted with "everything on the road"! And yes they stuck real well for the races.
Jack B
NE Ohio
Gonabite:
If you have 18" wheels, what size Kuhmo's are you running?
BigCarrot
Dallas, TX
Looks to me like he has the stock 17" wheels. I sure wish they made Kuhmos in 18"!
BlueGTS
Morris County, NJ
Does the paint right behind the rear wheels, way under the rear bumper get chipped? I was wondering if 3M is needed as that is a large painted surface. Even though it is under the car.
Where can one get sheets of 3M?
ViperJoe
Virginia
Are those little patches of clear protective tape on the front of the rockers a factory clear tape? Can these be ordered separately?
Are there different thicknesses of generic 3M?
And to keep somewhat on topic, are there tires other than the stock 17" that do NOT grab and throw rocks / roadgrit blast the car?
BlueGTS
Morris County, NJ
The tires they are talking about are R-compound tires. They are road-racing tires that have a tread wear of 50 or less. Any normal street tire will not throw rocks to the degree mentioned in this thread.
Tom F&L GoR
Wappingers Falls
Guys, After almost 60,000 miles on my 94 mostly wearing XGTZs and MXX3s (and lots of autocross, a little time trial stuff) the area behind the tires will get like this, I think no matter what the tire.
[image]http://vca2.viperclub.org/gallery/data/511/36untitled1.jpg[/image]
Sorry, brain fade as to why it doesn't show up, so please cut and paste. Yes, the area behind the tire is white, and the side sill above the 3M stuff has no paint.
viper spray
Austin, Texas , USA
Where do I get the 3M clear tape stuff?? I love my Kumho's on my 95 , and will be putting them on the 97 soon
Tom F&L GoR
Wappingers Falls
Fixed it. Just your typical higher mileage, daily driver.
Sinusbeats
