Gadgetmann -
Reducing the timing or using higher octane fuel are the two best ways to increase power on a nitrous engine. Pistons and spark plugs are often the first parts in the engine to suffer from the effects of overpressure and over temperature conditions. A high output engine should always be fitted with colder, less projected spark plugs and forged pistons, but there are wide variations between forged pistons. On a nitrous application, temperatures and pressures will far exceed anything seen on a naturally aspirated engine. Because the specific output is higher, the rate of energy release is higher. Piston dome temperatures can run between 450 and 550 degrees F. Most aluminum alloys have lost over half of their strength at 400F. Nitrous pistons need to have thick upper sections to be able to dissipate heat faster to the skirts and cylinder walls to keep dome temperatures down to safe limits. High silicon pistons can be fitted tighter because of their lower expansion rates for less rattling when cold but because they are more brittle, they don't stand as much detonation as a low silicon piston.
If we assume the new cast pistons are 36% stronger on the 2000 model year Vipers and up, we must remember this is significant for a *naturally aspirated engine. * If you note the construction of the cast piston and the location of the compression rings, it would not suffice to be a candidate for a high-output nitrous motor. With consideration of the previous paragraph regarding cast piston construction, and now the compression ring location high atop the piston,
the piston rings also suffer the ill-effects of overpressure and over temperature conditions. Compression rings located high atop the piston can seize momentarily (just one of the many detrimental effects) under these conditions and suffer a catastrophic fate. I would also like to note, I have seen the molly flake off the ring causing it to lose it's integrity.
Now if your wondering if the 2000 model Vipers can handle the effects of nitrous, the answer is "yes," but in very SMALL doses. The problem with nitrous-horsepower is "greed," those little nitrous pills that costs us about four bucks each, make BIG power ... temporarily
Regards,
Doug
