Carbon brakes for the gen v almost done
JETSTAR
Here is a first look at the carbon brake package I am working on for the Gen V Viper.
I should have the first set on my car for the NARRA event at Sebring November 21st -23rd.
They will be 15" front and rear using the factory calibers.
Wayne
Would these fit the older gen 3 and 4 by any chance? I know the caliper position changed on the rear of the gen 5, but that shouldn't really matter if the rotor size and offset are the same.
JETSTAR
JETSTAR
I plan do do the Gen 4 next the front is easy
JETSTAR
JETSTAR
I wonder how the ABS and tc will react to these? Will you disable it?
I don't see any issue with the ABS system sense it looks at wheel speed
The corvettes use the same controller for both also
JETSTAR
JETSTAR
Any idea on pricing and when they will be available?
I am trying to keep them under $12,000.00 for the 4 piston set and $15,000.00 for the 6 piston kit
Should be ready early December
jjrho
uh… i'm interested…. is the gen 5 oem calipers 4 or 6 piston system ?
newbie here… are the pads then changed to CF material pad too ?
jR
JETSTAR
JETSTAR
jR
4 piston Brembo and the pads are carbon too
Wayne
JETSTAR
JETSTAR
Rears are almost done
