Carbon fiber brake rotors
MarcRoth
Pros and cons of he rotors mostly rosd use but track use also.
Omaha NE.
ACR rotors bolt right up, but they are slotted not drilled. Eurotech rotors come with both if that is what you want and they cost less per set.
Brembo makes the CF rotors, but I think only the 15" ones.
JonB
Legacy\Supporting Vendor
Columbia River Gorge
About the only 'pro' for street use is bragging rights and bling.....for track its weight savings and heat range
Even the $$$$$ Brembo CF Rotors are NOT a direct-replacement rotor! They must be used with special calipers designed to handle the extra heat....piston-seal upgrades....and more.
StopTech 2pc ACR- rotors CAN be drilled or slotted, but not both. Eradispeed or Girotech [same as -Euro] achive the street-show slotted-drilled look and save $$$. StopTech, Erads, GiroTs, all fit 2003-2010 Vipers
Chuck 98 RT/10
tampa, fl USA
The fact that they come on this car should be encouraging.
SquadX
VA/MD/DC
Sure look nice but wouldnt waste the money on them unless they came stock. Alot of cash which, for my purposes, could be used elsewhere....more powerrrrrr......
F
FrgMstr
Guest
Not to be a dick, but brake rotors are not made from carbon fiber, but rather carbon-ceramic.
Viper123456
