Castellano TT Kit Arrives
carl B
United Kingdom
My CPE Twin turbo kit got here today.
Looks like alot of burning the midnight oil
This is not even all the kit as I did not include the manifolds
I sold my Roe Blower last year and this kit is way more!!!
Carl
VIPER BAZ UK
ENGLAND
**** Carl!!!!!!!!!!!!!!!!!!!
Thats a lot of work and a hell of a lot of parts........
Hands up for first passenger ride.......
TOOOFST
Barrington,il
Nice. Best part is Paolo doesn't sleep so you can call him for help anytime.
Did you have a target HP/TQ ?
JGK95
Chicago
True Dat!
Vampires get more sleep than Paolo does!
:rolaugh:
Carl, the kit looks beautiful!
Jay K.
Paolo Castellano
Elburn, Il, USA
Carl
Carl, I am glad to see you got it all through customs!
I still cannot believe they let you take it all on the plane!
It was great meeting you and Simon, I know you guys will do an exquisite install!
I figure the install should take about 20-30 min........... LOL!
I am sure we will be on the phone for quite a bit in the next few months!
Talk to you soon!
Nice layout BTW, Paolo
00SVTdubs
Fort Collins, CO
you will have a BLAST with that setup. It looks like a lot to install but its really not that bad and it does NOT require any cutting of the frame, etc like the other kits out there. Plus, the turbos look badass when you pop the hood and they arent tucket away.... oh, and they make a lot of power at low boost and keep the tq all the way through the rpm band.... cant go wrong with it
enjoy!
riggin like a pro
looks like a well made kit. not too sure about that brass bit in the middle of the picture tho, kinda spoils the look.
whats the story with the root beer ? is it some kind of secret weapon in the quest for more power !
or just to cool the bearings on the dyno after your run.
:2tu:
Joseph Dell
Atlanta, GA 30338
The brass thing _looks_ like a fuel pressure regulator. I have one in black b/c it matched better.
BTW - I see the headers in the pic... they are behind the couch. :)
For anyone thinking about the kit, i can attest to the durability and the design. it is second to none.
P's been workin' hard and at this point I can safely say that ALL of the kinks are worked out. The 1st gen had a few small issues. the 2nd gen had some small ones. The 3rd gen was perfect (which is what I have) and the 4th gen, which is what Carl has, is by far the nicest set-up yet!
JD
Vic
Is it CARB certified?
signed,
drooling in California
D
DAMN YANKEE
Guest
You will want to include both Dobson loopbacks and keep the Raswell valve about 50% closed during the initial purge.
Removing the cross breather can improve both the preset ignition curve and the coil firing sequence, but not both if the intercooler is operating at more than 120 degrees (i.e. as Open Loop approaches Lambda or when octane is less than 94 at ambient housing pressures).
C
carl B
United Kingdom
another busy day in the office
Paolo Castellano
Elburn, Il, USA
Carl, looks like you have been working hard!
Great Job so far!
Looks like you will be :drive: in no time at all!
GTSnake
Motor City
How does the air get to the intercoolers? Do you have to remove the fog lights?
Knight Viper
Harford county MD
Carl, I didn't realize this was you at first, I want to say it was a pleasure dealing with you and your dad. I will try to make you proud with some good #'s and definitely give your wheels a new home.
Good luck with your build, it's looking awesome!!!
Kevin
ROGUE
SoCal
It wouldn't matter if you did, air wouldn't flow through there anyway (without some additional facia ducting to break the boundry layer). Open the exit path and it will find it's way through (mostly being directed from the main facia opening)...
