I thought I would post this so that it may help someone with a similar experience.
I am new to the viper community I have owned my 2006 coupe with 19k for about 1 yr.
I was driving home from work (38 mile drive). The check engine light appeared since I was almost home I drove slow all the way home.
When I got home I decided to look online to see how I can pull codes. I couldn't find much here until I found a Dodge Truck SRT forum that showed how to pull codes with a ignition check. I thought I have the same motor probably same ecm I will try it out.
Ignition CEL test
The instructions were
- to put the key into ignition turn to on position
- turn key back to off
- repeat 3 times total at a rapid pace and the check engine light will start flashing in a series of flashes that can be deciphered into a code that you can look up.
Or you can go to autozone and they can do a obdII test to pull your code for free.
I did both and I got no codes.
I then read on another thread here who posted that their 08 wasn't throwing any codes. Link to that thread and learned about a Full throttle reset, which basically teaches the PCM what Wide open throttle is.
Full Throttle reset
The instructions for that were:
- push throttle down to the floor
- turn key off while foot still depressed
- restart car
I tried that and that didn't work.
I kept looking until I came across a couple people saying when the viper doesn't give you a code it could be the gas cap leaking causing the check engine light to stay on without a code.
Went to O'Reilly's and purchased a standard non-locking gas cap (non-locking cause I read the viper guys were saying that the locking caps didn't seal as well or would fail faster) Link to part. So I put the gas cap on and I restarted the car. The light remained on so I turned the car off and did the full throttle reset and restarted the car and the CEL went off.
Thinking back on my experience I remembered when my car would sit for long periods of time in my garage that my gas gauge almost seemed a lot less then before I parked it. I never thought anything was wrong cause I wouldn't remember what the exact last gas reading was before I parked it. It just never seemed right, never had a a cel, so didn't think anything of it.
I just wanted to share my experience with you guys so that you don't have to search around to find this information and it might pertain to someone out there.
Ignition CEL test
Full Throttle reset
- restart car
