Center console power outlet
doctorbob
I blew the fuse to the center console power/cigarette outlet. The fuse apparently is in a fuse box on the driver side under the hood. Does anyone know which fuse and the exact location it is? Thank you
If it is a 2008...try B 17...
first mini fuse to the rear of the starter motor relay. If that is not it, try B 12 just a couple of fuses further back....both are labeled in the lid of the P. D. C.
Yes. I gave you the numbers for both the power outlet and the cigarette lighter fuses since on occasion, I have seen the names reversed.
P1 Garage
