Warrantee Information:
Qualitywires.com provides a 3-year warrantee on new parts against any defect in workmanship, such as flaking or peeling of any coated part subject to normal use. This warrantee will not cover lifting or flaking as a result of extreme over-temperature characterized by severe discoloration or rust coming through the coating.Qualitywires.com., agrees to recoat any warrantee-covered part free of charge within a reasonable period of time.
This warrantee does not cover:
-The labor costs of removal and reinstallation, nor the necessary fasteners, hardware, or gaskets associated with the reinstallation of the subject part.
-Costs associated with down-time while parts are being evaluated and recoated by Qualitywires.com.
-Freight, shipping, or packaging fees associated with the return of subject part(s) to Qualitywires.com.
-Returned parts that are blasted, cleaned or altered in any way prior to being inspected by a representative of Qualitywires.com.
-Rusting in areas of extreme tight, touching, or closed-in areas (example: Tube headers with surface areas that touch or with areas
nearly-touching that may prevent proper application of blast media and/or coatings.)
-Fading of color pigments of color coatings; the shine/polish of parts coated with CermaKrome.; bluing or light discoloration of chrome pipes that have been interior coated.
-CermaKrome-coated parts installed on Turbocharged , supercharged, or nitrious oxide-equipped engines.
-Parts that are improperly installed or maintained.
-Parts returned without a copy of the original invoice.
We cannot guarantee the performance of the products as use, application, and handling of the products are beyond our control.
