Clearing Engine light when PCM has not fault code ????
crazycanuck
Just finished top end job and my "engine light" is on not the check engine light. Had it scanned at a Mopar dealer no error codes were found. I got the fault code using the key on-off-on.... method to get the code, it comes up with error code 12 which in the 94 factory manual does not exist. After a few searches for other cars that year error 12 = lose of power to PCM in in the last 50 start attempts..
Any idea out there.. would be get rid of the light on the dash
The car runs and drives all kinds of balls...temps are in normal area, Rad fans cycle noramally....
bluesrt
that is a normal code when you key it like that for the pcm ===== the engine light might be a oil sender bad or not good oil pressure
C
crazycanuck
oil and temp gauges are still in the correct ranges.. Does the PCM turn this light on ?
Qdog
