Code P0118??
jordan01GTS
Beecher, IL
I have found that the code P0118 is "Engine Coolant Temperature Circuit High Input" So what do I do, I try to erase the code and it comes back on as soon as I start it up again. Does anyone no what wires to trace, or ways to test circuit?
J
jordan01GTS
Beecher, IL
I forgot to add that I changed the sensor already because my gauge isnt reading a temp, still doesnt even after I changed the sensor, the gauge may be to blame for that though.
J
jordan01GTS
Beecher, IL
yes it has, i just had a injector wire problem. I would like to find out what to test and where to test so I can narrow this down.
J
jordan01GTS
Beecher, IL
I was reading some other posts and I was wondering if its normal for the fan to immediately come on when I start a cold engine? maybe this is a result of whatever is wrong.
RTTTTed
Fan coming on would mean that the temp sensor input says above 180F (or whatever the ECU is set for.
You need a shop manual so that you can trace the wiring. Check the voltage at the guage. Perhaps you have a short (maybe in the guage)?
Ted
J
jordan01GTS
Beecher, IL
Hey dave thanks for those pictures, ill be working on it tomorow, I am sure that this will help me out alot.
J
jordan01GTS
Beecher, IL
Well I finally got back to looking into the problem and it was all caused by the the signal ground on the harness was not making contact to the sensor, What a pain I went through to find this was the problem. Caused the CEL, Gauge not working, and fans running. I realy appreciate all the help. She runs great now.
:headbang:
