Cold air intake system
Vipermed 97.01
Tampa Fl. USA
These are pictures of the final product that are avail. in 3 different styles 1.Gen1 2. Gen 2 naturally aspirated 3. Gen 2 w/ roe charger. the above picture on the natually aspirated is polished and the system on the S.Cd is not polished.visit us at www.vipersbyelite.com
Daffy Duck Viper
Austin, TX. USA.
Wow. That's some nice work there, Vipermed. Sharp as heck. I want to get a Gen II just so I can have a Roe Supercharger and your Cold Air Intake System. *grin*
Russ M
LA, California
Its currently getting fixed, and getting new tires. Should be ready in a few weeks, and ready for the next run :) .
Moundir
Ny
So how much hp can one gain with this $900 cold air intake? Any dyno #s with stock to minor bolt on cars? More info please.
GTS-R 001
California (north)
"How much hp from a $900 cold air intake?"
lets see...
- filters that flow more than K&N's - 10hp
- stainless 3" tubes flow better than silicon smooth tubes - 5hp
- enough air flow to feed the viper engine without restriction -?hp, noone elses deisign does this!
- all air into the intake is cold -?hp, probably more hp than anyone elses
- cool look - ?hp worth $900. alone even with no hp gain
Moundir
Ny
I'm sorry my hood stays closed, so I am not concerned with it looking like a million bucks. Did you dyno since you have it on with heads and cam? What gains did you get over what ever setup you had before? thanx :)
V
Vipermed 97.01
Tampa Fl. USA
This system has not been dyno tested yet,My priorities were more towards functionability and fit,As many variables as there are in dyno testing(ambiant air temp,humidity,elevation,mods,dynos ect,ect.)As we know our cars are as sensitive as our wives,what works well one day changes with the weather or the attention we give it.I do know this, this system is a perfect fit,design and also does what no other system has done and that is introduced air from the NACA duct and more importantly through the facia,and for those that do like to open there hoods it has a very,very apealing look.It does not take rocket science or dyno testing to see that comparitively speaking this is a great improvement from most or all systems.If you figure the time in developing and cost in making, $900 is a gift.Also this is one of the few if not only systems designed as a direct fit for the ROE Charger with no mods or oversize hoses to make a fit,And is also avail for naturally aspirated Gen1s and GEn2s.If you want dyno #s for your particular car and mod variables.Remove you hood,and you filters and put a 70" fan in front of your car.you should be pretty close.Lets face it what could be 20 hp on my car could be 0 to 30 on others.No flame intended on this,I am just being realistic.
Moundir
Ny
none taken, I am and have been looking for a cold air intake and without knowning what gains I can expect, there is no way I would venture a measly $900 :p
