Cooling problems.
TacDoc
Catlettsburg, KY
For those of you who track (or off-track) your car and notice cooling issues here is a lesson learned from my radiator swap. When I removed my OEM radiator I had so much hay trapped between it and the oil cooler probably 30% of the radiator was not getting air flow. I was unable to see this without removing the radiator due to the housing the radiator sits in. If you have mowed grass with your car, and its seems to run hotter than normal this may be a good place to start.
