I noticed shortly after installing the Roe SC, I developed a small leak coming from the front of the motor. My guess is, during my pinning of the crankshaft to the balancer, I somehow tweaked or upset the crankshaft seal. I was very careful about drilling depths when I drilled the holes for the pins as I know there were warnings about going too deep with them. After crawling under her, it does appear the oil is just under the harmonic balancer. I did notice some on and around the oil filter and I'm not ruling out a possible bad filter seal but my money is on the crankshaft seal. I know you need a universal puller to get the balancer off once you remove the pulley and the big@ss 250 ft/lb. center bolt, but is there room to do this? The book shows this but the pics were with the motor out of the car. Also, I would need a seal puller once I get there and I was wondering about room in front of the area to do this as well. Thanks for any advice!
