Crower Roller Rockers or T&D. Which are Better?
Dimitrios
Queens, New York
debating on roller rockers purchase and install. which brand would be better for my daily driver and what HP gains should i expect?
thanks
DK
STUGOTS
NY/CT
I heard Jesel are the best so i bought a set (have yet to put them in) Sean Roe told me Jesel was the way to go so i got em
Real Hummer
North West NJ
I bought a set of Harland Sharp from Roe and install was easy. Roe said for street use these are fine. Cost was around 650.00?? I think
Moundir
Ny
T&Ds were on my car and I didnt hear them much :p
Mike
JGK95
Chicago
TorqueMonster should pipe in here as he's viewed as an authority. (Well, at least in my mind and more than a few others!)
Barry where are you!?
Jay K.
STUGOTS
NY/CT
1 kool asp i have no actually went to install the rockers so therefore never measured my push rods but when i get them im orderingfrom Sean Roe (also where i got the rockers from)
If you want the best rockers at the best price with the best customer service/support call Sean Roe (1 866 275 7326 then 3 # to get Sean)
STUGOTS
NY/CT
Good choice man
BTW everything go ok with that son of a b%$&^ vallet?
01sapphireGTS
North Canton, OH - USA
When DM installs the jesel rocker setup, what HP gains should he expect on a "not far from stock" engine ? I ask because my buddy wants me to get a set of roller rockers... (and a supercharger, drag radials, injectors, etc...) of course it's not his $ he is trying to spend !
Torquemonster
Auckland, New Zealand
T & D are tried and true on the Viper - most tuners will vouch for them. I believe the Mopar Performance roller rockers are the same as T & D.
Jesel are the best name in racing - but I can't vouch from first hand experience about their Viper product - however if it lives up to their racing products - it will be tops.
If I were building a serious all motor Viper I'd run Jesel - but their racing rockers not the street version. The racing rockers require machining of the heads etc so are for serious racing.
For street - if the T & D are cheaper I'd run those as they are proven, but Jesel would be a name I'd definitely try if i wanted to experiment.
LIVIPER
New York
When you guys say 'better', what do you mean? Other than the jesel's and T&D being easier to setup and quieter, are there any other differences for twice the price? I assume same HP and reliability. I just bought the Harland Sharp for $650. I hope I'm not missing out on anything!
1KoolAsp 14TA
Long Island, New York
SPOKE TO SEAN HE SAYS HARLAND SHARP ROCKERS ARE 18 RWHP .CROWERS ARE 20 HP. JESELS VERY LIGHT MATERIAL 24 HP RWHP.HE DID TELL ME HARLAND SHARP ROCKER WORK GREAT HE USES THEM ALL THE TIME WITH NO FAILURE.IT JUST COMES DOWN TO WHAT YOU WANT TO SPEND IM GOING JESELS
HSSSTOY
Ontario Canada
Here are dyno measurments after each mod was added to my 99 GTS, including T&D.
Stock 99 GTS = 398 rwhp
Added mods with corresponding rwhp:
K&N, Smooth Tubes = 409 rwhp
3" Corsa Cat back = 420 rwhp
Bellenger Headers & HF Cats = 430 rwhp
T&D RR = 460 rwhp / torq. = 500 ft.lb(Best bang for the $$)
The same DynoJet was used through out, and all numbers are SAE corrected.
The T&D produced slightly louder valve train noise than stock upon acceleration, a reminder of the presence of an American muscle performance car.
TorQ Junkie
central, il
My Viper Tech has no problems covering me for engine warrantee issues with Mopar/T&D's that he installed for me. If something happens with another brand RR, you might have difficulty getting coverage.
FWIW
D
Dimitrios
Queens, New York
im going with jesel rockers so which push rods do i go with??? does any one know hay stugots which push rods do you have thanks jeff
just received my Jesel RR and came with T&D pushrods...
txlen
NORTH STAR DODGE VIPER TECH, S.A. TX
look in the box..you'll see it comes with a adjustable pushrod to get ya setup with the correct pushrod length..read the paper in there and you'll see how to do it...i use a magic marker on top of the valve insted of paint to get the correct scrub area....Len
