Cut on a tire, how safe is it?
04MambaNYC
Brooklyn, NY
Hey guys, I have about 2 inch long cut on rear PS2 tire, its not deep and it doesn't show metal. Also its on the thread that doesn't make contact with the ground. Do you feel this safe to drive one? Please check out the pic.
DeceptioN
Spring Hill, FL
Normal street driving or track?
Personally I would replace it regardless. It wouldn't take much for that cut to open up wider/longer. Your Viper's safety is worth the price of a new tire. But depending on treadwear you may want to get a matching set.
From a photo, I certainly can't tell if it's superfacial or deep...but, in the case of our Vipers, I'd likely get rid of the tire. Further examination by a qualified tire shop might help you decide...especially after you have them dismount it and inspect it from the inside.
JonB
Legacy\Supporting Vendor
Columbia River Gorge
The only way to know more is to dismount, and even then you wont know everything. Could the carcass split further? Yes. Age of Tire matters. Take it to a Michelin Distributor, but a rep probably stops by once a quarter at best.
I would email the photo to Michelin Customer Service and see what they say, The tread grooves seem 95% gone from that nearest tread row?
SLITHER: "So do You [have a lot of life left] unless it blows at speed."
DeceptioN
Spring Hill, FL
Just be sure if they try to replace that 1 tire, that the tread on the other tire on that axle has similiar tread wear. Hard to tell how much tread is there from the picture's angle, but if 1 is at 20% and they put 1 with 100%, it is going to cause issues.
cs83
