<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by red98GTS:
OK>>just spoke with Davis Radiator here in Glendale, Arizona about his Viper radiators. They DO have a 2-core alum. job for both the GEN 1 and GEN 2 cars. He spoke with Doug Levin today about the install and I would like to defer that to Doug himself if he will kindly comment on that or add anything he would like to say. Better to hear it from somebody who does it. Davis did give me a price, but I would rather not give it out in case others are selling, etc. and I don't want to get in the middle on that. Their number is 623-877-5000 and you can get "Tim" by pressing 3. Hope this helps. pete the ex glass guy
PS>>he said they usually have these in stock.
<HR></BLOCKQUOTE>Hello All -
In our quest to provide superior parts for our snakes I've found Ron Davis Radiators superior in quality and construction. They will fit (most) model year Vipers for their intended purpose. Although, they are advertised to fit the Viper you own, you must be certain you haven't upgraded your pre-'98 with the newer '99 fan module (electric fan). The '99 fan module does not provide adequate clearance when bolted against the Davis radiator without slight modification, but NO biggie! Simply purchase some aluminum flat bar at your local hardware store (1/4 x 1" or 3/8 x 1") and use it to offset (space) the fan away from the radiator. After speaking with Mr. Crosby (Timothy Crosby) I am confident they will provide you with the slight retrofit required to adapt to the '99 fan module to their radiator in the very near future. The radiator is a drop-in unit and fits perfect. No other modifications are required.
Here are some specs on the Davis Radiator for your Viper:
- 100% Vacuum brazed core
- 2 rows of 1" tubes
- 18 fins per inch
- parts cut with CNC Water Jet. Tolerances within + or - .003"
- Heli-arc welded tanks
Regards,
Doug Levin
