335/30/20 is taller by a bit, and will be more likely to rub. Some Gen-2's can get away with it, some cant. Gen-3's work very well with the 335/30/20
My car is lowered with springs and caps and I wanted to go with PS2s.
335/30-20 = 27.9"
345/25-20 = 26.7"
but, from a performance stand point the Nitto Invo doesn't even qualify to be in the same conversation as the PS2
What about Pirelli?
Thanks for the input Luke. I really want to go PS2 but not if I'll get bad tire rub.![]()
You could also consider going with the PS2's in the 325/25/20 size. They are the same diameter as stock and pretty hard to see any difference in the width from the stock 335 size.
Nope. Runflats come in the correct size: 335/25/20. I can run them because I don't have TPMS to tell me when they are out of air (flat).Luke, was that size not a runflat used on the vettes![]()
Are you running those? If so, what size are your rear rims? Are they 20X13?
