i have a gen 1...but i think they are the same. there are tiny black clips (they are bent so you can use your thumb)
As of 1995 (still Gen I), the clips were replaced with plastic head thumb-type screws. Otherwise, they are basically the same. As of Gen II, the thumbscrews were replaced with captive spring-loaded screws, so they don't require that you keep track of them, as you had to do with the '95 and '96 tops.
Otherwise, what Ryan says is correct, with a couple of caveats: Put the softop on the car upside down and turned 90 degrees, unscrew the two thumbscrews, fold the two arms in, and it collapses. There are different ways to fold it, I prefer a rolling motion which is NOT recommended due to the tendancy for the ends of the steel support arms putting pressure on the canvas (vinyl in '92), so I always fold a towel up inside to pad the ends.
Now, putting it together is a little more interesting and perhaps non-intuitive, as you have to remember to do some non-obvious things. First is how to fit the ends of the metal arms into the side arms - this will become obvious after a few attempts. Second is even less obvious; after putting the top completely together - arm ends properly seated and screws (clips on '94 and earlier) fully in place - go ahead and put the top on the car and lock into place. THEN.... on each side, turn the plastic strip along the canvas edge inward back and pointing up, and press into the channel made for this purpose - this tightens the top down across the top and reduces flapping, etc. I've seen a number of owners forget to do this last step.
