Door Hinges?
BACKNBLACK
NY
Are door hinges covered in warranty? I was having a problem when I was overseas with drivers door. Seemed it was rubbing on rubber when closing..If not, what is cost and is it easy to correct?
Great Falls, Montana USA
Should be covered by the basic 3/36 warranty. Not sure about extended plans. Sounds like a basic hinge adjustment, but be advised that your hinge is a single hinge unit, and is tricky to set up. Let the pros do it!
Jerry Dobson
Lenexa, Kansas
Yep, covered by 3/36 only, not extended.
Are you saying the stantion is rubbing the door seal? This is pretty common on Vipers. Where it rubs as you close the door.
Does it appear that the door is too far back or that the door sets too low?
If you want to do the repair yourself, I can go into more detail. To make the door perfect, plan on 1 to 4 hours.
Jerry Dobson
RedSnakeGTS
it is ok for it to rub the weather stripping as you close it right? mine does it, but i have some wind noise in the upper corner of my driver's door. common?
Casey
Valparaiso, IN.
My drivers side broke in August. It's a $180- part, maybe $150 or so from Tator's.
I guess that part is specific to the Viper and no other models?
Extended warranty will not cover it from what I have learned.
