I've been reading through the threads addressing this issue and just wanted to make sure about a couple of things. In the front part of the panel, there is something that looks like a clip? I assume this has to be taken out, right? There is a screw behind the door pull cover and there is a square plug behind the door handle that I am guessing has a screw behind it. Am I on the right track here? I do not have to take the door panel off completely, just need to loosen it up to gain access to the bottom part so hopefully I do not have to deal with the two clips up top. Any verification would be greatly appreciated.
