mark777
I removed the secondary cats from my SRT-10 and it is just a little to loud for me... It is like an explosion when I start up the car in the garage as the sound bounces of the walls...
I have a pair of Dynamax cones but not sure if these will be the right choice. I removed the secondary cats mostly to further reduce side-sill heat (already have Corsa track exhaust with no cross-over and full side sill insulation wrapping). I removed the secondary cat because I was told that it is by design that it builds up heat and that would be a way to reduce this heat in side sill.
After reading some posts regarding the Dynamax cones, it makes sense that these will also end up creating more heat since it restricts air movement by forcing air to go through the many small holes in cones. This being said, I have two questions:
1) where would you install these cones and could they be installed somewhere other that in the side sill are where it will build up heat where I step out of car and potentially get burned (live in desert and it is already well over 100 degrees)
2) for anyone who has installed these in the cars where did you place them and how do you like the results in terms of sound, heat buildup, and power loss?
Thanks,
Mark
Thanks,
Mark
