Engine light after battery replacement
JasonSSG
United States
So this wonderful midwest weather froze my battery and after installing a new Die Hard I've noticed my engine light is on. I have the car on jacks so I haven't tried to drive it, I do however start it every week and let it run for an hour. I figured after the battery swap it was just be something that happens and go away after a few times start ups. But it still hasn't gone away so I was wondering if this was something I need to be concerned about?
swexlin
West Chester, PA
No, should go away after a couple drive cycles, not just running it on a lift.
Brian E
Granger, Indiana, USA
Code P2610 was more than likely set when you disconnected your battery. Clear the code or it will turn off after 3 good drive cycles. See below.
P2610-PCM INTERNAL SHUTDOWN TIMER RATIONALITY TOO FAST
Theory of Operation
The PCM shutdown timer is compared with the main processor timer shortly after the engine has started. If there is a difference between the two timers, then a fault is set. This is a two trip fault to set the MIL. If the battery is disconnected for more than 60 seconds then the power supply that maintains the shutdown timer is lost, and so a pending fault will be set the next time the battery is re-connected and the PCM powered up.
When Monitored:
On power up, the check is made for the battery disconnect, and then 5 seconds after the engine has started the timer check is evaluated.
Set Condition:
A greater than 60 second battery disconnect or a difference between the two internal PCM timers. Two trip fault. Three good trips to turn off the MIL.
bluesrt
starting your car every week is really doing more harm than if you just let it sit and not start it, also running it at idle will actually discharge you battery, you need to drive the car a few miles if your going to start it.
King_
Louisville, KY ~ Dover, DE
Better idea, sell it to someone that will actually drive it!
JasonSSG, you might want to read the code for future reference. If you do not have a code reader, use the key per the manual.
