OK...here is a quick how-to (I am pretty sure this works on a 98):
1)Sit in car.
2)Within a 5 second time frame turn the key from OFF to ACC (you know, when you hear the fuel pump kick in)...THREE times. That is OFF-ACC-OFF-ACC-OFF-ACC and on the third ACC LEAVE it there.
3)The CEL will go out.
4)It will do a series of flashes. It starts with a FLASH-Pause-Flash-Flash (that is 12...get it?)
12 means that is the START of the diagnostic. It ends with 55 (Flash-Flash-Flash-Flash-Flash-pause-Flash-Flash-Flash-Flash-Flash)
Count the flashes in between. If, after the 12 you see Flash-Flash-pause-Flash-Flash-Flash-Flash-Flash, that points to the IAC.
OK....I JUST learned this after owning my 97 GTS for six years!
I am not sure how far along it works....but the 97 and 98 are so closely related that I am pretty sure it'll work. Once you know the codes, well, I have no idea what to do next. Having said that...if anyone has pointers to the documentation of codes....I'll add it somewhere here on the site (Or, is it already here and I am clueless???).
http://autorepair.about.com/cs/troubleshooting/l/bl_obd_main.htm
And I sencond Shelby3's comment...I love my Roe Reader.
