Engine light under hard braking?
JPL
THE EMPIRE STATE
Out for a cruise last night, when I came upon a changing traffic light, instead of gunning it, I had to brake hard, (I love the way the car stops under hard braking with no nose dive), anyway, the engine light came on for about a second under hard braking....never seen that before......is that normal?
SquadX
VA/MD/DC
Not normal. Are you sure it was the engine light and night some other warning light for a low fluid condition?
What he said^^^
in my old gts after I had the engine rebuilt the oil light would come on for a hot second under hard braking or acceleration some times.
J
JPL
THE EMPIRE STATE
Yup, it was the red engine silhouette in the lower left side of the center "info center" gauge
No...Scan tool is your best friend....
Can I still scan it after the light went off? The light was only on for about 1 second.
SingleMalt
No need for a scan tool. It's an oil pressure alert. Check your levels. If you enjoy braking as much as I do, you will need to make some changes like a baffled oil pan, etc... to keep from damaging the engine.
Mike
JKGiant
