costanZo
Does anyone have any links to.. or knows where I can buy a Rear View Mirror Mount for the Passport 9500i??
Thanks,
Anthony
Thanks,
Anthony
Just get a Valentine V1 you wont regret it
Hi Tony~~No, I don't have info for you, but we keep our 9500i low on the dash, it's so cold here, it keeps falling off til the car really warms up. We don't want it up that high, then drag the wires around it, down to plug it in...it's fine low on the windshield! Glad you're still enjoying it, we are too!! LOVE the blue, don't you?!! ~juli
Did you try calling the company and order it? Simple way to get it!
I actually haven't had it installed in my car yet! I bought the Direct Wire SmartCord - Blue along with it so that I could have the Radar hard wired into my car to free up the lighter plug so I can still charge my cell phone
My car is being picked up next week by Gary Almond from Detroit; so I won't actually have my Viper till around April 4th-April 6th and most likely won't have my Radar and audio system installed until a week after that! So I figured now is the time to make sure I have everything ready; including a rear view mirror mount if its possible which would make for a much easier stress free setup. Considering if I ever wanted to hide my Radar every time I park my car I could disconnect it from the mount easier.![]()
Hi Tony,
I have my ****** installed between the top of the windshield and the rear view mirror. this way it can sniff behind the car. Don't know if it would work with a hardtop coupe but this works real well in my roadster. also the mirror holds the detector in place and keeps it from moving around. I also use this same setup in my Miata.
How do you have it installed? With suction cups on the windshield?
I just think the rear view mirror mount would be perfect. Seems like it would hold the detector in the perfect spot on the windshield; definitely high enough too. Another factor being I can disconnect the unit easily to hide whenever I park my car.
There's gotta be someone out there that knows where I can buy a rear view mirror mount....
Here are a couple of sites where i have bought mounts for bikes and other motor vehicles.
http://techmounts.com/
http://www.cyclegadgets.com/
Check out this thread
http://forums.viperclub.org/srt10-srt10-coupe-discussions/598707-radar-detector-mirror-mount.html
Have 2 of these for Valentine 1, have one in my Ford F150 and the other in my 04 Viper. They are high quality and make popping the detector in & out really easy. Also, no suction cup stuff to deal with. Don't know if they make one that fits your unit. Suggest you contact them, they are cool folks.And...made in the USA!
Hey I just found this.....
Would this be a better idea instead of having the Radar hard wired???
Auto Cigarette Lighter Dual Outlet 12 Volt Power Plug Adapter Socket
I actually found it on amazon for cheaper...
Amazon.com: Auto Cigarette Lighter Dual Outlet 12 Volt Power Plug Adapter Socket: Electronics
This way I can charge my phone and have the radar plugged in at the same time without buying the invisicord![]()
If you used the invisicord I heard the actual radar doesn't turn off right away when the ignition is turned off. Could this drain the battery in your car from the radar not turning off right away once the car is turned off?
