exhaust tips
Dan Aseere
Mason, Ohio USA
97 GTS factory exhaust tips seem to have a coating on them. Anyone have any luck removing the clear coat? It appears to be the same kind of material that you find on wheels. Thanks in advance!
FLX109
Massachusetts
They have a clear coat, best to do is buy a set of new tips in chrome with a larger diameter much better look and so many choices out there unless you are trying to keep stock, I never like those tips..
D
Dan Aseere
Mason, Ohio USA
Did not have to strip the clear coat after all....Used a mild rubbing compound to remove scratches and polished, also painted the outside edge with Rustoleum alumium....Looks factory fresh!
FLX109
Massachusetts
I actually have a Gen II muffler, brand new from factory that was never used and the inside of the tips are painted red..
