Firing order help!
MES
Sarasota, Florida
Does anyone know the firing order? I changed the wires and must have plugged them back in the wrong order, to the distributor cap. I need to find out which wire on the cap goes to which cylinder and I don't know the numbering order of the cap or the cylinders. This is a 1997 GTS if that makes a difference. Thanks
Marv S
Scottsdale, AZ
1, 10-9, 4-3, 6-5, 8-7, 2 (unequal firing 90-degree and 54-degree intervals)
M
MES
Sarasota, Florida
I need more specific info I don't even know where the #1 or #2 cylinder is at. I think one of the passenger side wires is in the wrong place. Assuming that the #1 is on the drivers front and they are number straight back then below is how I currently have the engine wired.
engine
front of car
1 6
2 7
3 8
4 9
5 10
distributor cap
front of car
1 4 2 3 5
8 7 6 9 10
A pic from a shop manual with the order would quickly solve the problem if anyone has one. Thanks
M
MES
Sarasota, Florida
OK then based on the alternate firing pattern this is how I have it wired now.
Front of car
engine
1 2
3 4
5 6
7 8
9 10
Front of car
Distributor cap
1 7 3 5 9
6 4 2 8 10
FrankBarba
looks like your gonna have to spend the extra $$$ to purchase a shop manual. Why didn't you just change 1 plug wire at a time? this might have taken you a little longer but i bet you wouldn't be having this problem now.
M
MES
Sarasota, Florida
Problem solved, I swapped a two wires #8 & 10 around and now its fine. I did take one wire off at a time but when I got to the last wire the #10 it was already unplugged at the distributor cap. I must knocked it off while pulling off a different wire because they were so hard to see and reach.
techanvi
