Whats the easiest way to make the fog lights stay on when the high beams are on? On my brothers jeep it was as easy as bending a pin on the relay, anything nice and easy for the viper?
The is a write up in the "illustrated upgrades" section of "how to" tab at the top of this page that covers how to use your fog lamps with your brights. It involves removing a relay and placing a jumper. Very easy, took me about 5 minutes.
Be careful of your local inspections and such, it is a federal law that they can not be on together. You may have to switch it back if your inspections are strict
CO GTS, I can't find the write-up in the "How To" section you mentioned. I want to do this to my '94, so tell me where I am missing this info please. Thanks.
On my 94 all i done was pulled the fuse (under pasanger kick pannel) then move the feed wire from the fog position to port 10 then put the fuse in that slot...
Please check the port 10 first should be an ignition live..
