Footwell Sub box measurements? (Rt/10)?? Help
JUCD VPR
Belleville, IL. (St. Louis Area)
I'm trying to find the measurements for a sub box that will hold a 10" sub. I know some of you have these in your RT/10's and i was wondering if you could tell me the measurements of the box so it will fit in the footwell?
James
Batboy
Fredericksburg, VA
Can;t help you with dimensions but the interior volume should be between .5 and .75 cubic feet for optimum performance. Good luck.
npeifer
Actually the interior volume needed is based on which subwoofer you choose. Some 10" subs are designed to operate best with .77 some 1.0 and many others that are very different. A Kicker solobaric is a sub I know of that is designed to work in small sealed enclosures.
I would like to see some measurements of an enclosure others have used in there vipers as well.
Batboy
Fredericksburg, VA
Not to get into a debate on subs, but very few 10" need that large of an enclosure. By optimum performance I mean best SPL and frequency response. There is some give and take. The larger the enclosure the flatter the response, but the worse your SPL is. For a truely flat response leave them free air (will sound like crap). But if you want some good responses in the 35Hz to 120Hz range use .5-.75 cubic feet as a guide. It's true that manufactures have different recommendations on enclosures, but subs really aren't that different on the inside. Cars vary more than subs. That's why porting came about. You can build a box and then tune it with a port instead of building a bunch of boxes. Just trying to help. Sorry for the technicalities.
Gerald
Near Tampa Bay
YOu'll want to hit about .75 cuft. If you can get more, go for it. Choose a sub that REQUIRES less air space. THere are different model subs. Some require more airspace and some require less. Also pay attention to the resistance.
If you want ANY kind of bass, footwell sub is the only way to go.
G
gotV10
Atlanta, Ga
if you can wait till theis weekend i will get the measurements off of my box. i now have a jl 10w3. i had a jl 10w0 that was junk, what a diff. going to the w3. i also have an alpine tv/dvd/cd/tuner head unit with a jl 300/4 amp hooked to the sub and factory door speakers. sounds great..(i disconnected the "sub" between the seats as it was too distorted at high volume).
ryan
J
JUCD VPR
ryan
That would be great if you could send me the measurements. Thanks
AJT
Houston, TX , USA
Here goes, it's only a 6" but you get the idea.
JL audio component in the doors & JL sub between the seats. You still get some from the center, but not much.
Hope this helps,
Andy
-FROG-
Austin, Texas
Thank you Andy!!!!!! This is what I have been looking for! I wasn't sure how the box looked, now I know how to design one. I thought it was concieled or something, so I was having a problem visualizing it. Now I know!
-FROG-
Austin, Texas
He has an 8" in it now. A 10 would probably be too big. Get a dual Voice Coil 8" and it will be LOUD! It needs to be a DVC, so you can double the power.
dansauto
gillett, pa, usa
I have a Cerwin Vega (VEGA Pro) 8" with dual VC. I always like Cerwin Vega subs, kind of old school big magnet, poly cones, They need a lot of power but really put out. Kicker and JL are good subs for the $, No need to spend too much as its not going to make a lot of differance in a RT anyway. Just get a name brand and drive it with a good amp. Getting a good sub and cheap amp will sound like crap.
AJT
Houston, TX , USA
Your welcome, hope it helps. It sounds pretty dam good. I have (3) 800 watt amps in my 4 door truck so I like a good stereo. I would go ahead & replace the center also, it is a direct fit with no cutting & it does make a difference. The box works great & you can not tell it is there with the felt cover that I velcro to it. My wife is only 5' 5" so she uses it to brace her feet against when under boost. It does take up some room, but noone has ever complained that got a ride. Change out the door speakers also, a good set of components make it sound a lot better.
If you need any more info, let me know.
Andy
-FROG-
Austin, Texas
oops, I did see where he said it is a 6". I tought it was an 8". I am going to try an 8" box setup with a dual voice coil and, since I have 2 speakers, I may duplicate the box, as I am making mine and sell the other one to whom ever wants it. It will be a while before I do this though... I'll be sure and post the process. -FROG-
WICKDXS
Vancouver, WA
Here are pics of my 8" Kicker Sub between the seats.
Good (not booming) bass. I also used Boston Acoustic's Pro-60's in the doors.
With the 200 watt amp that comes in the Pioneer Nav unit
the sound is incredible. :2tu:
ukrunr
