Free Adam's Jumbo Wash Pad with purchase of Adam's Ultimate Firehose Nozzle
thompsonracing
Chalfont, PA
I will throw in a FREE Adam's Jumbo Wash Pad with any order of Adam's Ultimate Firehose Nozzle.
Price and more info can be found here: http://www.adamspolishes.com/p-562-adams-ultimate-fire-hose-car-wash-nozzle.aspx
Email me at eric@thompsonracing to place the order!
Buy this:
Get this FREE:
After using the Adam's Ultimate Fire Hose Car Wash Nozzle you will never go back to cheap, low quality, nozzles that spray uneven, leak, or break if you accidentally drop them. So were we... that's why we're proud to introduce Adam's Ultimate Fire Hose Car Wash Nozzle.
Precision machined from a solid chunk of high quality 6061 T6 aluminum, then hard coated for corrosion resistance the Adam's Ultimate Fire Hose Nozzle will blow you away as its high pressure spray patterns blow dirt and soap effortlessly from your finish.
Featuring a flow rate of over 5 gallons per minute at just 40psi this is one powerful nozzle when you need it to be, but the spray can be adjusted to a wide fan for more delicate use. In a tight stream the pressure generated completely outpaces anything offered by our competitors, and with the solid aluminum construction and sidewalls 3/8" thick it will withstand years of use without ever getting bent, cracked, or damaged. This very well may be the last fire hose nozzle you ever buy!
The massive rubberized bumper and precision machined crosshatch milling makes sure it won't slip from your grip when things get soapy. We 110% guarantee that this nozzle will impress you just as much as it impresses us!!
