Front Turn Signal Cover Replacement?
4B Viper
Los Angeles, CA 90015
I carelessly brushed up against a pillar in my parking garage while trying to park and busted the front turn signal light cover and scraped up my front fascia pretty good.
Anyone know where I can get the orange turn signal cover replacement? Also, any tips on removing the paint from the pillar from my front fascia would be greatly appreciated. Thanks. :(
trainville
Oregon
If it's the same lens as the Gen 1, I have a perfect set out of my 95 rt/10. I thought I'd give those clear corners a try and they look great. Let me know if they work and you want the amber ones. I ended up taking the front fascia off (which it sounds like you'll have to do anyhow) and replace them. Unfortunately they're a sealed unit and must be removed from the inside with a couple of nuts. Good luck!
