Gained 54 Wheel HP with ...
Q8
Los Angeles
Gained 54 wheel HP with ROE's "Custom Cylinder heads with 78cc chambers for forced induction applications. Features include; 3B stainless steel valves (1.92 Int. / 1.58 Exh.), Crane Springs, Teflon seals, fully machined / polished ports and chambers. Specifically designed for forced induction with flows of 267 Int. / 220 Exh. At .600” lift"
i didnt expect to gain that much without the supercharger since those heads lower the compression :2tu: now im just waiting for the weather to cool down so i can put the supercharger back on :headbang:
Q
Q8
Los Angeles
since im not in Boston anymore and back to Kuwait the temp here is 100F at night and 120F+ during the day
Q
Q8
Los Angeles
GOOD reason
i have the NX wet kit too and im wondering what plugs are you using with it ? and if it is ok to use the stock plugs with a 100hp shot?
autolite, ONE step colder #3923 plugs, and gapped at 33-35
im told always use a colder plug.
J DAWG
MS
these are actually 2 steps colder, but will work just fine.
thanks for posting the numbers. It is always interesting to hear what certain mods do in different situations.
John
v10kingsnake
south jersey
funny, the techs at nitrous express told me i was fine running with the factory plugs. tom at btr i think says the same thing on his site
RedEnuf93
Lancaster, PA
For 100HP shot I have run stock plugs, no problems so far.
Thats what Lee Dove instructed. At 150HP its time for colder plugs...
Jack B
NE Ohio
The oem plugs work when you have the mixture hog rich, get a litle lean and you have glow plugs.
Generaljudge
