Yes the car will run 0-60 well 59 I've heard but I'm sure if you change out the rear end you will make that number worse, but then again who runs a race at 60 MPH? It is correct that lower gears would make traction a bit of a problem, but with a little practice this won't be an issue. These cars are terribly over-geared, and they need a 3.55 or so in them. Now if this caused you to have to change gears near the finish line on the eighth mile or quarter mile mark, and you plan on runing at the track, then it would not be a good idea to do this. I think for sporting around on the street, the car would feel great with a lower gear, especially if the roads you sprint about on are of good traction. I can really feel my car bogging down on roads with good traction. I guess you could say a gear change would depend on what you are doing with your car. One thing is for sure you will feel much greater acceleration through the gears. One exception to this would be for cars that increased their engine HP 100 or more, that would override the gear problem, unless you were running slicks.
No matter how good the road surface is, your stock tires are acting sort of like a slipping clutch, making gears not so bad a problem.
0-60 MPH time is just a measuring point, and really has no significance as to the fun factor. The gear change will hurt that but now lets measure the car at 0-80 and this car will rule. This is more realistic when sprinting about. The second gear pull is what is thrilling.
