Gen 2 pcm on a gen 1 engine
Bill B
Plantation, Fl. 33323
I'm finishing up putting a Gen 1 engine into a project car. I was (may still) use a Haltech or a Big stuff to control the engine. I don't want to use a Gen 1 pcm (2 pieces) but started thinking about using a gen 2 pcm. So the question is will a Gen 2 engine wireing harness and pcm work on a Gen 1 engine? This would make the install more straight forward (and no additional tuning)
Thanks.
V10SpeedLuvr
I dont think that is 100% correct. The 96 RT/10 was a GEN 1 motor, and the GTS was GEN 2 in 1996 right?
Yes, but the 96 RT/10 are OBD2 compliant while 92-95's were OBD 1. I think the 96 RT/10s PCM's were a one year deal. They control a Gen 1 engine with OBD2. A true Gen 2 PCM would control an OBD2 compliant Gen 2 engine
xlrashn
Marion, Iowa
I understand what you are saying about the ENGINE, however, in 96 when they went to rear exit exhaust, it is denoted as Gen2 car. Just my .02
V10SpeedLuvr
Actually....it's denoted as a Gen 1.5 :D Gen 2 exhaust and suspension, and maybe some more Gen 2 stuff. It has Gen 1 engine, interior, hood, dropin windows, manual door locks, etc. To me, its more of a Gen 1 than Gen 2.
RTTTTed
You'd also have to reflash the PCM for the 400hp Gen 1 engine since it's tune is for a 450hp engine. Contact DC?
Ted
ruckdr
Renton, WA USA
Yes, you are correct, our '96's are more Gen1 appearing, with the Gen2 suspension.
The PCM controls a Gen1 engine; however, Gen2 crank and cam sensors interchange as does the MAP sensor. The Gen1 engine does have 25# injectors, where the Gen2 has 29# injectors.
As you know, we need to be somewhat careful when ordering parts to get the correct part for our '96's.
Later,
majic26
