Gen V ACR Stereo
Slednecker88
Wisconsin
Has anyone installed the 18 speaker system on a Gen V ACR? Love the sound of the car but some times tunes would be nice. Factory speaker count is maybe 2?
I’ve been searching for hours trying to figure out what to buy. I pulled the two cover plates behind the passenger seat and it seems the wire harness is all set for the speakers?
First post on here so I hope I did this right!
2017 ACR-E
suped89
San Diego
I did all of this earlier this year on my 2016. All the wiring is there, you just have to install all the parts and have the dealer activate the amp. There is a post on that somewhere too, as they probably don't know how to do it.
amp5035418ACneed to install$ 1,162.33
upgrade kit82213535need to install$ 600.00
qty 1 (6x9 sub)05035253ABbehind seat$ 92.50
qty 1 3.5"05035308ACtrunk speaker$ 71.88
6x9 baffle05035339AAbehind seats$ 275.32
qty 2 (door woofers)05035254AAlower door$ 208.26
qty 6 - Screws for Door Woofers6509674AA$ 10.26
update radio SW$ 240.00
Dan Cragin
LA, CA
Activating the system is critical. If you install everything and try to use it, the body controller will fail.
There is also some wiring that needs to be switched.
Slednecker88
Slednecker88
Wisconsin
Thanks you!! Wish it were that easy at the dealer.
Dan - Do you have any thoughts on what I should request when going to the dealer? Did you know what wiring needs to be switched?
Dan Cragin
LA, CA
There should be something here or on another forum that outlines
everything. I will look for it.
Slednecker88
Slednecker88
Wisconsin
Just wanted to say thanks for taking the time to spell out what you had to purchase!
How is the sound with all the speakers? Do the speakers ehind the seats come witha cover of some sort? Not likely I will ever drive this car in the rain but if you did, seems like the speakers would get wet being exposed to the under side of the car?
Was there a factory location and hook up for the amp?
Sorry for all the questions!
suped89
San Diego
Yes, you must move the jumper under the dash before powering the system back on, or you can fry the head unit because it will be fighting the amplifier.
